Questions on upgrading my 99 concert system...
For my 99 A4 1.8QTMS:
I'm planning on installing a set of Boston Acoustics Pro 5.5's in the front and RX67's in the rears. Also I plan to run some sort of 4-channel amp to push the speakers. The question I have is, do I have to use the MB Quart adapters in the front doors? Or can they simply drop in without modification to the door. Also I know that the grill is shaped for a 4" driver, but will I also need to modify this as well? Any other adapters or hardware that I will need to do this install?
Thanks
Derrick
-Neuspeed race springs
-Bilstein shocks
-Neuspeed P-chip
-Ronal R-28's
Thanks
Derrick
-Bilstein shocks
-Neuspeed P-chip
-Ronal R-28's
Watch the speaker depth, some magnets will hit when you roll the window down. And get the Blaplunkt adapter for your line-outs. You'll need to cut the existing pin block to use the adapter, but IMO it's the easiest way to tap in to the radio for the amp. BTW, it's definitely worth it!!
super_gp
07-30-2004 04:26 PM
feelstranger
04-18-2003 06:58 PM
computrtutr
11-30-2002 08:15 PM
trapspeed
10-26-2000 07:49 PM
