Sponsored by:
Sponsored by:
Quick question about running a remote wire...............................
Old 07-20-2006, 04:23 PM
murray4225's Avatar
Default Quick question about running a remote wire...............................
I wrapped the end of my remote wire around a 20amp fuse and plugged it into an unused spot in my fuse block.
Anyone see a problem with this set up for my remote wire?
TIA
Old 07-20-2006, 05:16 PM
DirkM's Avatar
Default Isn't the remote wire supposed to go
from the head unit the amplifier to send the power on signal? What are you trying to do?
Old 07-20-2006, 05:34 PM
murray4225's Avatar
Default Yes you can run it from the head unit...
it simply needs to be hooked up to a switched 12v+ wire to tell the amp to turn on and off, I am using my stock head unit so I don't have one from the unit, I had to find a different location.
anyone see a problem with this set up? It works like a charm.
Old 07-20-2006, 07:19 PM
DirkM's Avatar
Default Ok, that should work
<center><img src="http://pictureposter.audiworld.com/86480/symphonyiidiag1.jpg"></center><p>But if you have the stock head unit, the pin with the switch symbol in the LINE-OUT section of the 20 pin connector is the remote wire for an amp. This way the amp will turn on with the head unit and not only with ignition on.
Old 07-20-2006, 08:07 PM
murray4225's Avatar
Default yeah technically I could have done that
but I would need a new connector etc..whatever this works perfect, I just want to make sure there is no problem with doing it this way? i dont want to fry anything, you know?!?!
owlicks
12-24-2007 12:47 PM
UltraRoss
12-11-2004 12:51 PM
lyonelll
07-10-2004 10:36 AM
brrman
12-17-2003 12:59 PM
WYSIWYG
9
12-28-2000 06:37 AM
Quick Reply: Quick question about running a remote wire...............................
