removing glove box
I am having troubles i got the 3 screws on the top lip of the glove box right behind the dash trim, then I got out the screw that was at the back of the smaller division in the glove box and then i got the two screws that are on the underside of the box, but there is still something connected inbetween the left side of the glove box and where the center of the dash beside the hu is. is there a trick that I dont know.
Ebahn manual shows only the three screws on the inside top lip and the three screws on the bottom of the hinge area. Then it states disconnect the electrical connections.
Hope this helps.
Hope this helps.
I took mine out yesterday (B6) there were 8 screws I believe. Some were very hard to get to.
2 below dash; three on top; three or four on the inside.
Just feel for the ones on the inside and make sure you took everything out.
Also, on the EXTREME passengers side of the vehicle the side portion of the dash pops off independent of the glove box on my model. I think that might be what's holding you up. Be gentle!
ATH
01-24-2004 04:11 PM
channelv
01-05-2002 08:35 AM
