Removing interior trim questions
Any tips on removing the interior trim piece down along the door sills in a 2001 S4? Are they held in with spring clips, or are there hidden fasteners that I'm overlooking? Also, is there any easy wasy to get speaker wire into the rear doors? Do you need to take off the lower B-pillar panel?
The door sills are held on with spring clips - You just pull upward on the trim. I also think there may be a screw at the front and back of these pieces. As for the rear door speakers, you have to remove the B-pillar. Unfortunetly you have to take the top piece off first, and then the bottom piece. The top piece is difficult, and has two clips at the top. Pull these out first, and then slide the piece upward. The bottom piece also slides upward, and comes out real easy once the top is removed. As for putting the wires in, I was able to snake my wires through the connector between the door and the door jamb, there isn't too much room, but it is possible. Good luck.
How do you replace the interior Driver side door Trim? any articles or writeups? I Stfa'd but failed
owneds4
01-28-2005 03:25 PM
