rewired whole system, no sound from NAV
so, i installed my system (almost, have to build a box for the sub)
But, I installed the DA Hex s500s in the front doors (pain, lots of trimming)
Installed the Adire Koda's rear deck.
Ran new 14g wire from all the speakers to the amp/xover.
I am not using any power from the deck, as I used the 4 Channel RCA adapter to hook up to the AMP.
Finally got my new instrument cluster to display NAV.
All work, however, no audio from NAV. I started with NON Bose, so I guess the nav/phone is built into the stock speakers.
Is there any way to get audio out of the NAV now with aftermarket speakers? Any help on this would be great.
Thanks!
AlexM.
Thanks!
AlexM.
<center><img src="http://www.nav-plus.com/instructions/images/symdiag.jpg"></center><p>The Basic Navigation System is connected to the stock HU. If you replaced the stock HU you may not be able to hear the sound. If you HU is still stock, the BNS navi should be connected to the middle section of the 10pin plug.
Deck: Stock Head Unit
Fronts: DA Hex s500s
Rear: Adire Koda 6
Sub: IDQ 10v3
AMP: HiFonics Zues 5ch
I redid all the wiring and used the blau adapter that plugs into the line out section of the rear HU and provides 4 channel RCA and remote on.
The sounds from the radio/cd/changer all work. The NAV is still plugged into the 10pin. However, no sound is coming out.
I think that it has to be VAG'd somewhere, but I tried to recode the radio, tried 00205/00207/00005/00007, none of those recodes gave me audio out from the NAV.
Any other ideas?
Rear: Adire Koda 6
Sub: IDQ 10v3
Any other ideas?
1) see link below for adjusting the nav mute amount
2) did you recode for a bose setup(see link)
Maybe 00117 or 00017??
http://www.nav-plus.com/instructions/programming.html
Do some trial and error with those codes to see if it works.
Good luck!<ul><li><a href="http://www.ibiblio.org/tkan/audi/radios/symphony.html">http://www.ibiblio.org/tkan/audi/radios/symphony.html</a</li></ul>
Tbandido
12-14-2005 07:34 AM
Bitchin Fast
06-17-2003 02:16 PM
sjjon00S4 NJ
10-29-2002 05:08 PM
