running new speaker wire through the doors or splice into the factory wires?
I'm trying to finish up my system and a friend said THE way to go is to splice the speaker wire at the door so not to pull more wires through. However, I don't really want to screw with the factory system as one day I may get rid of the car and would like to just put the factory system back in (maybe)..... but also, the speaker wire that I've got is a LOT better than what Audi is using and seems pointless to splice it there at the end and create a weak link in the set up.
Any ideas?
Any ideas?
adapter there anyway....... i'm fine with running the wires.
in my opinion at least
and you can always replace stock speakers - just splice the wires back together if you go back to stock
I don't think i'm going to get the cross overs in the door, but how the hell would you come off the cross over and then splice the wiring in the door........?
I fit my crossovers in the doors no problem. It may help to remove the cover (the inside of the doors is already fairly well sealed and so long as the electrical components don't touch the door cards, you shouldn't have an issue with them
if you don't want the crossovers in the door, however, you will need to run wires through the door jamb
sharmask
04-24-2007 01:32 AM
animalcracker885
12-26-2005 05:21 PM
Igor2003
05-03-2003 10:27 AM
