Sirius satellite radio
Greetings.. I removed the sirius tuner from my 2005 A4, and want to put it in my '06 TT. The car was purchased with the pre-wire option. i've located the prewire, and attached accordingly. However, when the SAT button is pressed on the radio, all I recieve is a NO SAT RADIO. I'm do not want to pay 150 to have the thing installed. ANY HELP!! (with pics or without) would be greatly apperciated..
Thanks in advance..
ajtt@preshainc.com
Thanks in advance..
ajtt@preshainc.com
There is probably a canbus wiring harness near the front passenger kick panel...
...that needs to be "reinserted".
Do a search in the tech section for what was outlined for the B6 A4.
Good luck!
-Ted<ul><li><a href="http://audi.barrystuff.com/s4/satRadio/s4_sat_canBus.pdf">http://audi.barrystuff.com/s4/satRadio/s4_sat_canBus.pdf</a</li></ul>
Good luck!
Re: There is probably a canbus wiring harness near the front passenger kick panel...
I looked at the diagram, and it is NOT similar to what my car has. When u mentioned "reinserted" do you mean take out and place back into orginial slot? thx!
Did you ever get your sirius installed? Did you need to move the canbus connector and where was it?
