Some audio questions about rear door speakers in my 96' A4
<center><img src="http://pictureposter.audiworld.com/110327/web.jpg"></center><p>I recently removed the interior trim of my rear doors to find that there is a nice pre cut spot for some 6.5" inch speakers.
Setup
40 x 4 watt Alpine Amp
Front Doors: 4" Infiniti 2-way
Rear Shelf: 6.5" Polk 2-way
600 Watt mono Kenwood Sub Amp
10" JL Sub
My question is this: There is plenty of high and plenty of sub bass but not much mid-bass with this setup. Would it be a better idea to just put in the woofer of a 6.5" component system or put a low pass filter on a 2-way speaker (like above) for the rear door speakers?
Thanks
Setup
10" JL Sub
Thanks
You'd be better putting a couple of 6.5" subs in the rear deck (JL 6W3v3-4) for the mid bass and then moving the rear deck speakers to the door and high pass them at about 120Hz to keep the low frequencies away from the doors.
I did have DSP which was a major factor but it can be done with proper tuning.
The fab work would be more worth it to improve the front mounting and maybe a larger driver which will give you the mid-bass you want from the right direction...
How how does this sound;
5.25" Component up front
6.5" 2-Way Rear Door
6.5" Subs Rear Shelf (as advised by response below, though I don't know how I would enclose them. open maybe?)
S4's have 6.5" 2-Way speakers in the rear doors as well as the rear shelf right?
I am biased in this category as I work for Elettromedia, but we are known for our "out-of-this-world" mid bass response.
