Sony Ericsson HCB-30 bluetooth kit HELP!!!
AudiWorld Expert
I am helping a local AWer install a bluetooth kit (HCB-30) in his A6. It was taken out of his former car, and I do not believe that he has the installation instruction book. First, I wanted to confirm the wiring:
Red - constant power (with integrated fuse, but I am probably going to switch that to an inline fuse)
Blue - ignition powerBlack - negative ground
Yellow - mute
Is this correct?
The other question I have is whether or not the yellow Mute wire works well with the Audi head unit. I read on a support forum (I think from the UK) that the yellow wire sometimes does not carry enough current to trip the mute function in radios. Does the yellow mute wire work well with your factory head unit?
TIA for any help!!!
Yellow - mute
Is this correct?
TIA for any help!!!
did a quick google search and found the user guide...looks close enough...
<ul><li><a href="http://www.sonyericsson.com/downloads/HCB-300_UG_R3a_Multilingual1.pdf">http://www.sonyericsson.com/downloads/HCB-300_UG_R3a_Multilingual1.pdf</a</li></ul>
flynnb
Q7 MK 1 Discussion
04-01-2015 03:10 PM
LSCOLMAN
01-12-2006 02:03 PM
Boston Driver
09-27-2005 05:01 AM
viks007
02-19-2004 08:16 AM
