Stock Navigation Won't Turn On!
The factory navigation in my b5 won't turn on anymore. There is no power going to the deck in the trunk where the cd is loaded and when I try to start it up with the controls next to the emergency brak nothing happens! I checked the fuse but the manual says it's one slot and the sticker on the panel says it's something else. Regardless I checked all my fuses and all were fine. I had to remove my radio to replace the fuse behind it not to long ago...is it possible that I messed something up when removing and reinstalling the radio? Has anyone had this problem??
1) check the fuse behind the nav drive in the trunk; could've blown...maybe unrelated
2) find someone with a VAG-COM and check and see if there are any error messages. Worth a shot. Could be a quick reconfigure exercise.
3) check power connectors behind nav CD-drive. You could try to disconnect them...and reconnect them to see if it resets itself.
Good luck!
Good luck!
I didn't even think to look behind the drive for a fuse. It took awhile to take it out but atleast I found the problem. I wonder how I blew it...oh well. Thanks man!
Danny
Danny
S4LUVR
Audi Original "S" Cars
05-12-2003 06:21 AM
