Sub and Amp connection help...
I have an old Sony ES XM 3546 that is 35X4 or 100X2. I would like to use this amp to run a single JL Audio 10W6 DVC. I will wire the sub in parallel to acheive a 3ohm load. The part that I can't figure out is how to wire the amp to get the max power out of it. The manual shows how to wire it in 2 and 4 channel configuration, but I want to wire it in a mono config. Any help would be appreciated.. Thanks in advance!
what you want to do is bridge both channels and run one channel to each voice coil
make sure u match ur gains and processing though.
Bjw444
A4 (B9 Platform) Discussion
11-13-2017 08:15 AM
Ground_Pounder_65
05-02-2005 04:28 AM
16PSIBRICK
06-06-2003 10:46 AM
sebdery
05-29-2003 12:28 AM
