Taking out factory radio
Can someone help me with instructions to take out the factory radio on a 98 A4, i tried fiddleing with a fingernail file for about 10 minutes with no results. Does anyone have deatailed instuctions like what direction to push to release it?
AudiWorld Expert
If it's the Concert unit (middle volume ****), I pulled one out a few weeks ago with metal nail files. If you have the same, I could probably figure out which way I pulled/pushed/etc
AudiWorld Expert
the clips you are trying to move need to be pushed inwards towards the center of the unit. So take the file, and angle it so it's sliding along the outside edge of the hole until it stops. Then with the end of the file you are holding, push it outward so the tip of it goes inward, moving that clip. While doing this on both clips, shove your third hand into the cassette opening and pull out on the radio. If you don't have a third hand, have someone "give you a hand"
SoCal B6 S4
08-28-2001 10:46 AM
