thanks for all your guys help, but ive got one more question about my install
alright i installed my new subs in my trunk in custom fiberglass boxes, but i think i did something wrong, because im not getting the bass that i did out of my old subs, im getting sounds like what you would get out of a normal speaker, voices and singing and stuff, instead of just a nice clean bass
oh and right now they are connected to my 4 channel amp, in the rear channel, in parallel wiring. but would i gain more bass by connecting them in a series wiring and then "bridge" them too the rear channel on my amp?
thanks again
thanks again
As to the wiring depends on the impedance of the subs and the capabilities of the amp.
Personally I wouldn't hang more than one sub off a 4ch amp if you're using the other 2 channels for the fronts.
Sounds like you are seriously lacking enough power to drive 2 subs off just 2 channels of a 4ch amp.
I'd run the 4ch amp just for the subs, each one bridged across 2 channels. You quadruple the available power when bridging an amp, so if it's a 4 x 75wrms amp, then you'd get something like 2 x 300wrms bridged. Don't know many 4ch amps that'll give you more than 4 x 75wrms, and you can't run any sort of sub off 75wrms.
so, should i run all four speakers off of my reciever and run the subs off my amp?
but that again brings up the question of will i be able to hear them like i cant hear the rears now?
thanks
thanks
8. REAR CHANNEL FILTER MODE SELECT SWITCH (MODE)
"HPF": Slide switch to this position if the amplifier is used as a mid/tweeter amplifier.
"OFF": Slide switch to this position if the amplifier is used as a full-range amplifier.
"LPF": Slide switch to this position if the amplifier is used as a subwoofer amplifier.
(this should be LPF,right?)
9. REAR CHANNEL HIGH-PASS / LOW-PASS FREQUENCY SELECTOR **** (FREQ)
Select high or low-pass crossover frequency between 30 to 300Hz.
(whats the best number to set this too?
10. REAR CHANNEL BASS BOOST CONTROL (BOOST)
Select a boost level between 0 dB and +18 dB to enhance the bass performance of your
sound system.
(what should this be set too?)
thanks again, i really appreciate it
sound system.
A6AvantErik: MCS
10
03-22-2009 04:25 PM
Sinister A4
08-02-2004 04:05 PM
dimeadip
01-06-2004 12:39 PM
SKareKrow
07-03-2002 10:57 PM
