Use stock wiring for new sub?
I've been searching the forums all night but i can't find answers to this.
I need two things: more bass, and every inch of loading capacity i can get.
I have two things: a Kenwood active 10" bazooka laying around in the garage and the 10 speaker non-bose system (upgraded with a new 2 channel speaker system in the front doors).
So i was thinking maybe i could tap the Ken sub into the original wiring behind the panel in the trunk? This way it would be easy to remove the sub when i need the space, keep the stock look, and hopefully i would not have to tear the interior down and rewire the whole car?
I mean all the cables are there - power supply, ground, remote...
Can it be done? How?
You can't use the stock power supply to run anything other than the feeble stock sub, it's about a 5amp cable. You need to run a new power cable, but everything else is there (remote on, left & right pre-outs)
It should be relatively easy to figure out by a process of elimination. The remote on & perm live are easily found with a 12v testing screwdriver. The speaker outputs or sub output should be pretty obvious, ground likewise, so then you should have 3 or 4 wires for rear pre-outs (left, right & 1 or 2 screens).
Audi wiring would be fried as soon as you attached the Cap which will pull as much as it can to charge itself up. Power Caps are really a band aid (or a gimmick) and should only ever be connected directly over the battery, if ever connected at all.
Anyone with a sub and factory head unit/HX_Guy when you ran your sub what did you use for power and,
UltraRoss
10-26-2004 07:57 AM
A4_Jax
10
05-17-2004 11:17 AM
AUDI 90 (88)
03-04-2003 10:23 PM
SharkWeb
12-19-2002 01:06 PM
