VSS & FM Antenna - Avic Z1
After installing a Avic Z1, getting the soundgate VSS can modules for VSS signal. I am still having issues with FM recepption. I know older VW/AUDIs needed a Antenna Adapter with 12v trigger lead, but with my 2004 A4 there is a second white wire by the bose amp. Is this wire used to turn on the factory amplified antenna? Is it worth to even start messing with the factory antenna or just put in a aftermarket amplified fm/am antenna?
Teddy, is obviously the expert any help you could give would be greatly appreciated.
Also anyone going for the all season high proformance tires? like the Pirelli Pzero Neros? or the Michelin Pilots?
htfan1
02-02-2009 06:12 PM
Oettinger_A4
08-13-2005 03:29 PM
Ground_Pounder_65
05-02-2005 04:28 AM
sebdery
06-10-2003 10:51 AM
