What is the difference in sound between a ported box and a regular sealed box?
check out the link for a nice looking ported...<ul><li><a href="http://www.soundillusions.net/sites/sixthfloorfreak/Pictures/DSCF0042.JPG">http://www.soundillusions.net/sites/sixthfloorfreak/Pictures/DSCF0042.JPG</a</li></ul>
it all depends on your music preference. if you're big into rap type music (and want the bass to be heard outside the car) then ported is good to bump with. on the other hand, ported enclosures almost always require a lot more space. if you want clarity, stick with seal boxes. these days they can get real small.
eg. 12" Diamond Audio M6 needing only 0.8 cu.ft while capable of handling up to 500w RMS easily
You just can't buy a cookie cutter box for your sub and expect it to sound good. If you design the box per the speaker's specs, sealed or ported will both sound good.
building each, specific to each of their subs. So if both boxes are built to exact specs, which one will give tighter more accurate bass?
and yes, design is everything. an average sub with a properly built box will sound better than a high end sub in a cheap enclosure.
4Rings::G2 boosted::
Mid Atlantic Discussion
19
03-01-2006 04:07 PM
IBD SV
08-22-2002 12:56 AM
black quattro
03-11-2002 08:05 AM
Bseven2.0T
01-27-2002 11:36 AM
CMC
07-05-2001 04:39 AM
