what do you guys think?
What do you guys think of this setup I'm going to install?
Fronts- 5.25 Ctd Hd-5 mid, mb quart psc 216 crossover, mb quart 1" tweeter (Unfortunately the mb quart 6.5" fronts won't fit) I will have to either purchase the autoleads adapter or create one out of mdf
Dynomat extreme speaker kit for both sides
Rears- undecided, either 2 or 3 way 6.25 coax
Subs- 2 12" kicker solobarics
2 amps
Zapco 350ag 2 channel (fronts)
Rockford Fosgate 600a4 (rears + sub)
I am going to run everything off the stock 99 a4 headunit. I have an rca(6) adapter and will run all the stinger rcas through the middle of the carpet, and under the rear seat.
I'm not exactly sure where I should make a hole for the power cable, some are against running it near the ecu, some for. I will run the power wire through the Right hand side of the floor trim. The speaker cable will be installed on the left hand side.
Speaker cable stinger 12gauge, sub cable stinger 8-10gauge
power cable is 4 gauge split into 2 8gauge (stinger)
The amplifier installation will be a bit trickier because there are two amps, a cap (1farad), a sub, and a 6 disc changer. The changer most likely will have to be repositioned. I am trying to retain as much room as possible for luggage, groceries, etc. Here are some pictures of the trunk and possible mounting positions.
Any tips would be great!
http://www.geocities.com/eddielakr/car1.jpg
http://www.geocities.com/eddielakr/car2.jpg
http://www.geocities.com/eddielakr/car3.jpg
http://www.geocities.com/eddielakr/car4.jpg
http://www.geocities.com/eddielakr/car5.jpg
http://www.geocities.com/eddielakr/car6.jpg
http://www.geocities.com/eddielakr/car7.jpg
2 amps
E-mail me your mailing address and I will send you a template I made<ul><li><a href="https://forums.audiworld.com/audio/msgs/38704.phtml">My previous post about 5.25 install</a></li></ul>
AthruC
06-04-2005 11:29 AM
StMarksa4
11-27-2004 07:59 AM
HDClown
04-08-2002 12:58 PM
GaryJ
10-07-1999 01:38 PM
