whats the diff between dual channel, multi-channel, and mono channel
I have three tens and the are bridged. The the encloser has one +- port. SO when i purchase my new amp do i want to get a multi-channel, why or why not, or shold i just get s single channel???
thanks
thanks
dual/multi channel amps are just that, they divide their power amoung separate channels. when you bridge those channels to essentially max out the possible power of the amp (which you technically won't) it will result in my higher THD and overall a ****ty signal. THEREFORE, get a monoblock amp because it will have a clean signal, full power and low THD....
btw make sure you know the ohm load of the setup...=)
<center><img src="http://www.crutchfieldadvisor.com/S-AjGa87YvvYw/reviews/20030722/subwoofer_power.html"></center><p>In most cases, a single channel amp would be the best for you. They can usually take the lower impedance, which you will be sending bause of the 3 subs. A dual/multi channel amp can't operate at the lower impedances.
You can find a full selection of amps by pointing your browser here:<ul><li><a href="http://www.crutchfield.com/cgi-bin/ProdGroup.asp?c=3&g=130&s=0&cc=01& avf=N&search=">You can read more on it here:</a></li></ul>
darkstalker
06-04-2003 08:27 AM
digitalskate
12-17-2002 07:15 PM
Bimmer Love
12-12-2001 10:18 PM
