Where to run power wire thru the firewall?
Okay, I'm finally ready for my stereo upgrade tonight. Got all the stuff that I need. Now I was wondering do I need to drill a hole to run my 4ga wire thru the firewall? Or is there already an opening by the ECU? This install is on a 01 A4. Any commments anyone? Thanks
I went through the ECU without problems. Some recommend it, some don't. Alot have gone through a grommet behind the clutch I believe. Fairly easy to run also. Best bet is to search though.
This is where I drilled a hole:
<a href="http://www.slipoftime.com/audi/audio/power_cable/power_cable.html">http://www.slipoftime.com/audi/audio/power_cable/power_cable.html</a>
There is where you could run w/o drilling a hole. I'm using it for my boost guage:
<a href="http://www.slipoftime.com/audi/boostguage">http://www.slipoftime.com/audi/boostguage</a>
Look at the firewall pictures.
I had a upgrade done and the assbag drilled a hole in the same spot, he didn't silicone the hole and I ended up with six inches of water in my backseat.
Sidebar: Took the car to Audi to find answer they told me I had a crack in my sunroof frame. It took some hunting but finally discovered the problem.
rskelme
03-17-2007 09:14 PM
Uhlinator
05-09-2004 10:40 AM
A4 Pilot
08-09-2002 04:46 PM
Bill In SoCal
03-26-2002 06:05 PM
