Sponsored by:
Sponsored by:
x-post Replaced the stock A6 Bose tweeters with Audax silk domes
Old 01-28-2006, 11:33 AM
Murph's Avatar
Default x-post Replaced the stock A6 Bose tweeters with Audax silk domes
I just did the fronts today with p/n TM025F13. I put these in as a friend in the high end speaker biz gave me 4 for the A6. The Bose tweeters are 4 Ohms and so are these. WOW it's so much better! The highs are now crystal clear with excellent tonality. My wife stated the difference was like taking cotton out of your ears. I had to dremel off the mounting flanges so they would fit. I had to tack glue them in place as the metal holding clamp no longer fit around the magnet. R & R of the door panels is well documented and easy. Then I just popped the little clip that holds the Bose tweeters, and replaced with the dremmeled Audax ones. Piece of cake! Sorry for the poor quality cell phone pics. My digital camera has decided to cease functioning. My stereo system is now starting to reach the the acceptable level for me without having to tear out all the Bose amplifer components (well not yet anyway).
Tweeter backs - stock Bose is on the right
<img src="http://pictureposter.audiworld.com/69962/tweeter_labels.jpg">
Fronts
<img src="http://pictureposter.audiworld.com/69962/tweeter_fronts.jpg">
After dremmel cutting
<img src="http://pictureposter.audiworld.com/69962/bose_and_audax.jpg">
In the door with the grille popped
<img src="http://pictureposter.audiworld.com/69962/tweeter_in_door.jpg">
Old 01-28-2006, 04:49 PM
HIS4's Avatar
Default Do you have more pics showing how you mounted the tweeters?
I may be looking into some Seas Lotus components but I haven't taken off the door panel to see how I could mount them yet.
Old 01-28-2006, 07:11 PM
Murph's Avatar
Default It was really easy. Sorry I do not have more pics however...
the stock Bose door tweeters are held in place with a metal retaining clip that just pops off. All I then had to do was desolder the speaker wires. The toughest part was cutting the Audax mounting flanges off with a dremmel cutter so the new tweeters were about the same diameter as the original ones. I then spot glued the remaining Audax flange to the door panel as the Audax is deeper than the Bose. There are a couple of plastic bosses on the door panel that the tweeter sits on. That is where I applied the glue. I also used some trusty duct tape to hold them in place while the glue cured. In addition the panel backing foam will also hold them in place. This was really very easy and made a huge difference in the sound of this system. I wasn't going to do this after reading several posts about changing transducers with no better performance. I knew these tweeters were so much better and if needed could fiddle with the hidden EQ codes since I have an 01. I am now set to 65558655 as the 8 really makes the I Beam I have mounted on the rear seat kick.
I am looking forward to another warm day in NH to do the rears.I am also looking forward to Boston Driver helping me R&amp;R the package shelf so I can mount the IBeam to the bottom. There's way too much vibration now from it. I think that Audi picked the rear shelf as the starting point and built the car around it.
Good luck on your tweeter install. You will be glad you did it.
Here's a pic of Bose on left and dremmeled Audax on right still with rough cut.
Old 02-08-2006, 06:47 PM
MarcSavage's Avatar
Does anyone know if the Bose B6 A4 tweeters are 4ohm as well?
Old 06-15-2006, 12:06 PM
FKI
New Member
FKI's Avatar
Default Re: It was really easy. Sorry I do not have more pics however...
I think I asked, but not sure if it posted properly.. Any place to get those Audax tweeters online?
Thanks
Karush Avagyan
06-02-2017 04:11 AM
Murph
15
06-18-2015 09:34 AM
drjet
12-02-2006 12:22 PM
Idoktr
14
06-01-2004 03:10 AM
Benfiam
03-22-2002 04:36 PM
Quick Reply: x-post Replaced the stock A6 Bose tweeters with Audax silk domes
