anyone do the clear bra???/
which company to use.... 3M has been advertising alot lately....
anything I should worry about , as far as discoloration or using waxes or anything else... tia!
Developed by the 3M Company, Scotchgardâ,,˘ Paint Protection Film, (SGPPF6)is a virtually clear 6Mil (0.006-inch) film designed to reduce stone chipping and bug damage on painted surfaces. Itâ€<sup>TM</sup>s a blend of acycloolefin, copolymer and a thermoplastic urethane, a tough, conformable material that is covered by a clear coat layer. This rugged transparent material will not crack, shrink or peel over time and it resists yellowing, the film and clear coat layers contains a protection to counteract harmful ultraviolet (UV) and infrared (IR) radiation that can cause the surface to occlude (cloud)
Ensure that there are no surface imperfections before installation. Clean and maintain its surface with Z-8 Grand Finaleâ,,˘ Spray Seal) or a plastic cleaner (Plexus® Plastic Cleaner, Protectant and Polish) start at the centre and work outwards, do not use a foam pad / rotary buffer / abrasive compound on the plastic surface. Tape the edges of the auto mask when polishing the vehicles paint.
Note: if the film is properly applied to a fully cured painted vehicle, it can be removed, usually in one piece, without damaging the paint surfaces beneath the film.
JonM
FWIW- most companies are using 3M's SGPPF6 film
JonM
mofos
Auto Detailing Discussion
05-25-2006 01:18 PM
Mr. Blasty
10-17-2004 10:22 AM
Generic
9
09-29-2003 10:37 AM
