Anyone use a pressure washer, on light setting of course, to wash their car?
Does your clear coat offend you?
Washing a car requires only hand pressure from holding a sponge. If you've got bigger problems than that, you've got some big problems indeed.
there is a demo video of a man washing his car with a pressure washer. I definitely don't do this but I'm sure you've seen this done on the dealer lots. I think with careful use it shouldn't do any harm. Keep it on a light setting and the nozzle about 8" away from the car.
Who uses a sponge to wash their car? ;o)<ul><li><a href="http://www.crspotless.com/">http://www.crspotless.com/</a</li></ul>
and see those pressure dudes hosing down all the cars in the morning, I cringe. It's really just an attempt to speed up the process since they have so many to do. I bet the soap they use, heated and pressured, is enough to take rust off lawn furniture. Sheesh!
Since most people do only one car at a time in their driveway, what's the problem with a sponge? Same with drying, I use the Absorber and it's not nearly the drudgery those spotless folks are trying to indicate. Now if I had to do second and third story windows on my house or some nasty concrete, pressure wash is the way to go. Not necessary for car.
it connects to a garden hose, so it's not very high pressure, but it does have a nice spray like a pressure washer. its lightweight, and you pur your carwash shampoo into the little handle, and it has a switch for soapy water, or just water. best thing i got for washing my car since the car itself
best of all... no need for a bucket!!<ul><li><a href="http://www.firststreetonline.com/product.jsp?id=31303&promotion=86072">this is what it is</a></li></ul>
Pressure Washer:
Electric powered high-pressure washer's can be used everywhere that a normal mains pressure hose would be used, but you should take a few precautions with there use. Beware of forcing water into areas were it can't drain, and don't hold the nozzle too close to paint surfaces for as well as impact damage an excess of water pressure could damage paint surface, it can also remove stripes and vinyl graphics.
Be careful when working with the pressure hose nozzle close to the vehicle paintwork, or while working in confined places like engine compartments as it could recoil and cause impact damage, try to keep a three or four foot distance and use the wand at a 45 degree angle
They are an ideal tool for the cleaning of fender wells and undercarriage, and for the removal of road salt from these areas.
JonM
JonM
Yes, I do use one but only after I open up the fan spray to the point I can place my hand 2" in front of wand w/o any discomfort. This creates a perfect 'water broom' effect to remove soap, etc, and only has a 1gpm flow rate which is perfect for my deionized water unit.
p3u
Auto Detailing Discussion
01-26-2009 09:22 AM
Vijay
RS4 (B7 Platform) Discussion
15
07-05-2007 05:57 AM
RickM
09-10-2001 07:07 PM
Paul V
06-30-1999 09:23 PM
