Brilliant black S5 - removing minor scratches + detailing
New Member
I have a brilliant black S5. I just picked it up at the end of February and am looking to do an exterior detail on it.
The paint has some very minor swirl marks - probably from the dealer prep. It also has some small areas of minor scratches (when I made the mistake of trying to remove bird poop using a gas station windshield washer squeege).
This is the first nice black car I have owned and first time doing a full detailing. I have researched in how to properly wash/detail and my plan was to:
1) Use Menzerna Super Intensive Polish PO83Q with a random orbital polisher & a Lake Country 4" Orange Mild Cutting Pad on just the areas with scratches
2) Use Menzerna Super Finish Nano Polish PO106FA with a random orbital polisher & a Lake Country 4" White Polishing Pad for the whole car
3) Seal with a hand applicator & Klasse High Gloss Sealant Glaze
Any comments on this approach or alternate product recommendations? I read Audi's had hard a clearcoat so this is why I was thinking about the super intensive polish/nano polish vs the intensive polish/final polish.
Your combination of products looks great, it should take care of your detailing needs. I'd advise you to stick with the polishes you mentioned over the IP/FPII combo.
One piece of advice with Klasse High Gloss Sealant Glaze, it can be very finicky during the removal process. What I found works best is applying it as thin as possible (use a smaller dispenser bottle if possible) and once your done applying a panel, go back and remove it. At the end, it's worth going over with some cold distilled water or a quick detailer with a plush towel to ensure you removed all of the HGSG.
If anything, swap out the Klasse for a sealant that is easier to apply and remove.
Hope this helps,
George
Hope this helps,
George
New Member
Thanks George. What would you recommend as an alternate sealant? I was looking at:
Wolfgang Deep Gloss Paint Sealant V3.0
Chemical Guys M-Seal Micro Finish Factory Paint Sealant -Protection System
Optimum Opti-Seal
Optimum Opti-Seal
Bang for the buck, Chemical Guys M-Seal is a great sealant. Easy to apply and remove, looks great on all colors and offers a few months of protection. You can't beat the ease of use of OPT Opti-Seal, simply one of the easiest products to apply and it has a great look to it. I haven't used the Wolfgang sealant so I cannot comment on that. Blackfire Wet Diamond with Polycharger is another great sealant to take a look at if you have it available to you.
I personally would go with either of those sealants over Klasse strictly on the time and effort that will be saved on removing the product. Klasse does offer outstanding protection and a great look, especially when you get 2 - 3 layers deep, it's just very time consuming.
Keep us posted on what you end up using and how your results turn out.
Cheers,
George
Cheers,
George
ACSGP
10
04-24-2007 09:09 AM
FastMarkA
Auto Detailing Discussion
13
04-14-2005 07:21 AM
Kevin M
11-17-1999 08:18 PM
