Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
Engine shampoo - DIY or take it to the Dealer?
Old 02-02-2007, 10:26 AM
Audi Advocate's Avatar
Default Engine shampoo - DIY or take it to the Dealer?
Is it really as easy and safe to "spray and wash" with a can of do it yourself from the car parts depot or should I leave it to the dealer?
Thanks!
Old 02-02-2007, 10:53 AM
Member
nynyvtecjstkickdinyo's Avatar
Default .......
<ul><li><a href="https://forums.audiworld.com/detail/msgs/34211.phtml">https://forums.audiworld.com/detail/msgs/34211.phtml</a</li></ul>
Old 02-02-2007, 12:20 PM
SKIroad'r's Avatar
Since when do dealers know how to detail?
Old 02-02-2007, 01:54 PM
Senior Member
phred's Avatar
Default That phrase scares me
engine shampoo? What exactly is the problem with your engine - is it leaking fluids so it's all nasty, or is the plastic that envelopes it just dusty? Modern engines don't get nasty enough anymore to use Gunk, they just need a mop 'n' glo with some soapy water and then a plastic treatment.
Old 02-02-2007, 03:13 PM
schnellmb's Avatar
Default simple green and h2o in spray container.....
spray on a barely warm engine...use brush is needed. lightly wash off (mist) with hose and don't aim at electrical components. start car to evap stuff off.
Old 02-02-2007, 11:09 PM
A6Gary's Avatar
Default What I have done for years is to take the car to a DIY car wash & use the high pressure...
soap spray for the engine block and surrounding engine bay areas, and then rinse. This process removes the road grime build-up, but won't make it look like a "detail" job. However, I'm careful not to point the high pressure water stream directly into the electrical connectors/components. This method works in winter or summer, and doesn't requrie hours of work. The engines in my three vehicles ('96, '98, and '00) look clean (close to new) doing this about twice per year.
Old 02-03-2007, 07:38 AM
NickS's Avatar
2nd!
Old 02-03-2007, 01:14 PM
Default DIY - My only fear is screwing up the electricals - thats why I let the dealer do it
I'll try the Simple Green + water route - thanks for the word!
Old 02-03-2007, 03:36 PM
islingtonaudi's Avatar
3rd! A couple of old toothbrushes don't hurt either.
Old 02-03-2007, 04:31 PM
New Member
HaimA.'s Avatar
Default Make sure you cover the coil pack,alternator and anything else that ..
might make the car run poorly with a towel and dont direct the water there either.
Quick Reply: Engine shampoo - DIY or take it to the Dealer?
