glaze v. polish - what is in a name?
I think that part of the confusion here is that product manufacturers are using these terms interchangably. for example, as Ted K points out, Mequiars show room glaze is designed as a polish. Also 3M, on their website defines glaze as:
Glaze
A polish that is safe for use on fresh paints. Some glazes contain a mild abrasive that will remove minor surface imperfections. When a glaze with an abrasive is used, it should be followed by application of wax on cured paint or a hand glaze on fresh paint. A glaze also does not contain silicone.
and:
Polish
A specially formulated blend of components designed to remove minor paint surface imperfections, such as fine scratches, light oxidation, water spots, and swirl marks left by the use of rubbing compounds. Polishes may or may not contain waxes or silicones.
therefore, I officially declare it pointless to argue about polish v. glaze (or the order they are applied). since we may be all talking (typing) about different products with different properties.
suffice it to say, you use the most abrasive stuff that is appropriate for the job then move on to less abrasive stuff and finally wax.
Finally, with respect to Imperial hand glaze, according to 3M's website, this is a paint "glossifier" and paint protectant. It contains no abrasive compounds. Logic would dictate that it be applied last, just prior to the wax, which simply protects the finish.<ul><li><a href="http://www21.3m.com/dr/v2/ec_MAIN.Entry10?SP=10024&PN=16&V1=37835&am p;xid=28181&DSP=&CUR=840&PGRP=0&CA CHE_ID=0">http://www21.3m.com/dr/v2/ec_MAIN.Entry10?SP=10024&PN=16&V1=37835&am p;xid=28181&DSP=&
Glaze
and:
Polish
Why do some many people report it removing swirl marks?
I personally have had **** luck with it removing any swirl marks.
Some pads can produce a fine cutting action that will level the surface and remove the swirls. Generally though, I guess the IHG just hides the swirl marks by filling them temporarily.
chzpig
07-09-2013 01:29 AM
DeadLy
Auto Detailing Discussion
08-24-2007 03:53 AM
SilvrBulleTT
05-28-2005 05:21 AM
KingA4
05-19-2004 08:45 PM
Black Sunshine
05-20-2003 05:57 AM
