Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
Help: Got wax on Black Trim
Old 11-09-2002, 03:12 PM
QuattroPwr's Avatar
Default Help: Got wax on Black Trim
Hi all,
When recently waxing 89 90 Quattro I accidently got some wax on it's plastic black trim that goes around the body. When it dried I noticed it left this pale-white-bleached out look on the black trim (so it looks very odd). I tried using wax remover on it (probably a dumb idea) and it caused the same effect if not worsened the trim more. Is there anything I can purchase / do to get these nasty marks off besides painting over it, or will it just fade off in time as wax eventually does? Many thanks.
Chris Leydig
Old 11-09-2002, 05:34 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default Rubbing alcohol usually dissolves wax.
Most bug and tar removers are also quite effective. Not sure what kind of "wax remover" you used (never heard of a product marketed as such).
Old 11-09-2002, 08:12 PM
AudiWorld Expert
mpwolf's Avatar
P21S GEPC and then wax again with P21S wax.
Old 11-09-2002, 08:24 PM
QuattroPwr's Avatar
I used an industrial strength Wax remover, it removes grease also
Old 11-09-2002, 10:42 PM
JohnLZ7W's Avatar
Try a vinyl/rubber cleaner. 303, Lexol, One Grand ERV
Old 11-10-2002, 04:18 PM
LI-S4's Avatar
Default That's easy...Harly PolyGard or One Grand ERV...
Use the Harly PolyGard if it's interior trim and the ERV if it's exterior.
I bought a FUBA antenna that was used and the black plastic was faded and washed out from the overwax and age. I gave it a shot of ERV and viola'
Just like new!
Old 11-10-2002, 06:11 PM
QuattroPwr's Avatar
Default Re: That's easy...Harly PolyGard or One Grand ERV...
Where Can I buy the ERV? Perboys maybe?
Old 11-10-2002, 06:49 PM
JohnLZ7W's Avatar
Default Unfortunately that isn't likely... I've only seen One Grand stuff sold online
<a href="http://www.carcareonline.com/onegrand_index.html">Car Care Online</a>
Old 11-11-2002, 09:19 AM
Rest In Peace
Jeff Vader - boscoj's Avatar
Default I would be lost without this stuff . . .
<center><img src="http://pictureposter.audiworld.com/15888/prekleano.jpg"></center><p>
Old 11-11-2002, 09:47 AM
QuattroPwr's Avatar
Yup thats the same stuff i used...bad idea to use it on the trim tho .
Quick Reply: Help: Got wax on Black Trim
