How important/necessary is it to wash after using Bug and Tar Remover when following up...
...immediately with a glaze/polish, and then a wax? To the extent it matters, assume P21S Bodywork Conditioning Shampoo, One Grand Tar, Gum, and Wax Remover, 3M Imperial Hand Glaze, One Grand Blitz Wax. Basically I'm wondering, given the following process:
1. Wash car with P21S Bodywork Conditioning Shampoo, Rinse, Dry.
2. Remove any remaining tar and gum with One Grand Tar, Gum, and Wax Remover.
3. Wash car P21S Bodywork Conditioning Shampoo and/or Rinse and Dry to remove residual bug and tar remover solvents.
4. Polish/Glaze with 3M Imperial Hand Glaze and Buff Out.
5. Wax with One Grand Blitz Wax and Buff Out.
How important/necessary is Step No. 3 above, and what should it include, a complete wash rinse with soap or just a quick rinse with water only? Thoughts?
Depends on what's been left behind.
If you see residue left behind after applying big and tar remover, I would wash for obvious reasons. Otherwise, the bug and tar remover will evaporate off the paint, so if it looks clean, proceed with your detailing regimen.
For heavy duty cleaning, like the lower panels during your spring cleaning, I would probably do the bug and tar remover, rewash/dry, reinspect (for possibly another round of bug and tar remover, and go from there.
For spot cleaning, I wouldn't bother...once I've got the area clean, I would move on to the next step.
i question the necessity of step one...
unless the car is DISGUSTING filthy (i highly doubt anyone here has that prob), i'd do the bug/tar FIRST, then wash/dry, etc. But i agree i'd want to wash off the bug/tar remover before IHG and wax. So do that first.
Bug and tar remover doesn't make a very good lubricant.
Anytime you rub something across "not-clean" paint, you want a lubricant...car wash soap, instant detailer, something. Without that, you risk added swirls and fine scratches in your paint.
More emphasis on 4, no emphasis on 3.
You need to invest a bit of time making sure the glaze does its job in step 4. It's really the key step that brings out the 'real' shine. My method does not have step 3.
The wax in step 5 just covers the lovely shine with a clear barrier, so you need to be sure that step 4 produces the end-result you want first.
Have fun!
--Seymour<ul><li><a href="http://home.earthlink.net/~chab41/audry02index.htm">Audry2 Web Site</a></li></ul>
Have fun!
I don't like first part of the routine....
Wash with Dawn dish soap. P21S is too wimpy for this part.
I think the Dawn and a little rubbing will get the tar.
Skip this step. Everything you use has a petroleum "base". Right?
In don't think step 3 is necessary if you're going to glaze, polish and wax afterwards. If you're..
really concerned, give it a shot of One Grand Show Off quick detailing between the tar remover and the glaze, but that's as far as I would go. Also, you may want to try P21S Total Auto Wash citrus degreeser also. I use this as bug and tar remover, and it has other uses (one less specialty product to buy).
Hope this helps.
Hope this helps.
Is DAWN the only product to use to wash car with to remove wax? Can any other dish washing detergent
03A627 2 04A842
Auto Detailing Discussion
05-03-2004 10:23 AM
T-28-Quattro de VT
07-27-2001 01:43 PM
