MTM Hydro foam cannon help needed
Hi all, I purchased an mtm hydro foam cannon. The first time I used it, I was able to get some foam but not like I see in all if the videos. The second time not so much. I know the soap I used is capable if it. I believe my issue is with the settings. I can't figure out how to dial it in correctly. I have the front nozzle setting closed so the front two plates are pretty close to each other creating a pretty wide fan. Not completely closed though. The other setting not sure where it should be as I don't see any markings on it. I'm using a 2700 psi gas powered Tri bilt power washer. Any help would be appreciated as company is in Italy and I can't seem to get answers anywhere. I want to have the excitement of using this thing that I thought I would have when I ordered it. My Audi is asking for lots if foam.
It took me a while to figure it out. I played around with some Meguiars car wash to get the hang of it then moved over to Chemical Guys stuff.
I can tell you that mine is screwed all the way on both settings - nothing "in the middle". Both for the spray and **** on top.
The other suggestion I would have is to dial down the pressure slightly. I use a 2700PSI also and I found it works better backing off the throttle a bit.
Thank you for the advice. I actually called wayfair and told them that u did not think it was working properly and they sent me a new one. I should have time to try it this week. Let me ask you a question though. Do you have the cannon attached directly to the gun or did you connect to the long silver wand where the nozzles usually go.
I can't believe it. I finally found out what the issue was. It sound stupid but may help someone else. It was not the foam cannon. The hose that I had going from the water to the power washer was one of those thin cheap coil hoses. I found out that the power washer wS not getting the right amount of water pressure due to the small gauge of the hose. When I switched it to a normal hose it worked perfectly fine. I guess you live and learn. Hahahahahahaha. Thanks for all of the help though
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
09-24-2015 05:34 AM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
