My Menzerna Plan
#12
Original factory spec is the 5-inch weight. My 7424 definitely came with it. Still have that in a drawer somewhere.
Afaik, some retailers are swapping it out to the 6" counterweight before selling. It *may* also be possible that new batches of 7424 are coming from the factory with 6" weights now (unconfirmed tho).
#13
You will go broke if you try and use only those products to detail with. Find your local detail supplier and see what they have to offer. you should be buying in bulk as much as you can, for wheel cleaner, shampoo, wax's, and other stuff like that. most of your customers wont even really know or care for the expensive stuff. give the optimum line a try its alot cheaper. As far as the little green clean machine goes its a good machine and definatly worth buying. I have a $700 extractor that just broke so I bought the LGCM as a back up And I have to say it does a pretty good job. its not quite as good and not as fast but a very nice machine. Your on the right track though practice on your buddys cars.
#14
As onuris noted, some resellers install the 6" weight or include it with the machine. We are a factory authorized distributor.
#15
crank it to speed 5 or 6. don't worry, you won't burn your paint. I'd suggest getting yellow cutting pads incase the orange doesn't cut deep enough and a green pad. the final polish II works well with a white and green pad.
and if you're using the high gloss pads from classic motoring... the black pad is for glazing...the red pad is for sealant.
detailersdomain
Auto Detailing Discussion
22
09-21-2006 11:54 AM
Grim Reaper
19
11-28-2004 07:26 AM
