Need some porter cable help...
I've started my bi-yearly detailing routine today by giving my car a good wash, clay, another wash, paint cleaner, polish, and eventually carnuba wax... For the first time, I'm using a porter cable and so far it seems pretty easy to use. Wax goes on really well and efficiently... But I'm having some problem getting the wax OFF the car. I'm using a terry cloth wax remover on the porter cable and though most of the wax comes off the paint, there is still some residue left over. It's not immediately apparent but if I tilt my head or just look at the car at certain angles, I can see all the leftover wax. Even if I go over the spot again with the PC, I still can't get it all off as efficiently as I want. This has forced me to use my trusty ol' microfiber towels and a little elbow grease to get rid of the leftover wax, but all in all, my routine is still taking me 6 hours + to complete... I was hoping that the PC would reduce that time...
Am I doing something wrong? Or is this just how it supposed to be? I always got the impression that after you apply wax, the pc would be able to remove the wax in a jiffy... er... maybe not? Please help!
or applying wax, as you've noticed, its faster to remove the residues by hand using a MF cloth,I'd swkip the terry cloth for fear of adding swirls or scratches.
the PC simulates (as close as possible) natural hand movements but does it 100x faster and better.
it would take a significant amount of time to match the results of a PC pass when doing by hand. The PC wont neccesarily cut down alot of your time detailing, but should make the end result eons better.
btw, I dont use the PC to apply wax, I apply and remove wax by hand and only use the PC for cleaning steps. wax is real esay on and off by hand with a properly prepared surface.
just my .02
just my .02
polish steps.
my spring detail will be with 3m finesse it II followed by 3m swirl mark remover, then a final pass with p21s gloss enhancing paintwork cleanser. all with a pc
ill finish with s100 wax by hand.
Yes, you can use the "Random Orbital" buffer to remove swirls, light scratches and apply waxes. The degree of success you have with removing scratches depends on the abrasive products used, type of pads and your expertise. Many people blame the buffer when in fact there are other variables that affect the outcome. The DA buffer is pretty easy to just pick up and operate but to really "master" and get the most out of really takes some time and proper technique which many people miss.
A "Rotary" buffer, which develops more heat and spins faster, is more capable of removing light scratches and swirls 'faster' and is able to remove more significant paint damage that the DA buffer cannot handle. The Rotary, however, is a more difficult tool to learn to master and easier to make "mistakes" with.
idge
Auto Detailing Discussion
15
01-11-2002 01:01 PM
ec-s4
01-08-2002 08:12 AM
Silvr1.8T
10-14-2001 10:23 AM
