what is the best soap for a foam cannon?
does it stick to car for a few min or does it run off quickly? Adam's Car wash seems to foam up but
quickly runs off car. Perhaps my ratio is off, do u use a certain water\soap ratio you like?
In part it's going to be a function of how "slick" the car is
A car waxed yesterday will be different than a car waxed five weeks ago. Also will depend on how dirty the car is. Ideally, I want the foam to stay on long enough to loosen dirt but then run off taking the dirt with it. When I put mitt to car I want (while foaming with my other hand) most of the dirt gone from the initial foam walk around.
sorry I wasn't clear
I do a spray-down of the entire car with the foam gun on a hose. Then I put the washmitt on my right hand, foam gun in the left, and wash the entire car foaming a panel immediately following up with the mitt with periodic stops to rinse out the mitt in a bucket of clear water. Hope this helps. I seem to stay fairly swirl free between semi-annual polishes.
A4tek
Mid Atlantic Discussion
07-21-2005 12:28 PM
escapA8
11-11-2003 11:55 AM
LeadingEdge
10
09-19-2003 04:11 PM
