what kind of pads would you guys recommend for a buffer after just painting and wet sanding
AudiWorld Expert
clear coat is still a little hazy and not really giving me a mirror shine.
AudiWorld Expert
went from medium cut to the swirl remover. I used a cotton pad though. It still looks like I could get a little bit more shine out of it though. Any easy to get polishes that you would recommend to get the final finish done. And I guess I'll get a wool pad for it. Thanks BTW.
mainly with fillers,I like to use the Menzerna twins IP & FP,they're a bit more work intensive but the results are longer lasting.Troy can fill you in on the Meguiars line in more detail.
have used the wool pad. That pad is made for post-compounding and will itself result in a hazing that will require further polishing. Sounds like you've done a lot of work, going backwards to the wool pad will just erase some of that.
As for the Meguiar's 3-step process. It's OK. Their pro line is better (#80(?) orbital polish & #9 SMR are recommended) but Menzerna is better still.
06A8
Auto Detailing Discussion
10
05-27-2007 01:46 PM
maxh2o
05-04-2006 04:32 PM
washparkS4
04-28-2006 10:39 AM
