do you lose ABS with stoptechs or ecs tuning's II kit? or any big brake for that matter?
Though it is theoretically possible to screw up the ABS system with over_the_top calipers and pads, I've never heard of anyone with a problem. At worst, I suspect some of us have deviated a bit from the optimum calibration set by the engineer who designed the ABS system.<ul><li><a href="http://www.stoptech.com/whitepapers/abs_bigbrake_122701.htm">ABS and Big Brakes</a></li></ul>
AudiWorld Expert
When I was tracking a ton...I got the ABS controller to act real weird like...hard to explain..something to do with the wheel sensors. I could imagine conditions where the ABS system..expecting OEM stuff...gets a bit confused with the aftermarket stuff.
Even though stopping distances would be shorting with ABS active, I normally try to threshold brake on track and stay out of ABS. One 30 min track session could be the equivalent of a lifetime of ABS use for a "normal" driver on the street. I really don't think the ABS system is designed to handle the extreme service it would see on track.
AudiWorld Expert
The back end would also fishtail in straight line braking...felt very odd.
gh0st
Motorsport Discussion
19
10-08-2006 09:20 AM
