Need opinions please on New Pads and Rotors...Alcon 4 pot brakes
#11
The 95.5 S6 with EDL and 4-channel ABS doesn't have one AFAIK. My 94 S4 has 3-channel ABS, a rear diff. lock instead of EDL, and a proportioning valve.
It is possible I am using the wrong rear piston sizes in the calculator. I am going by what has been published online. Next time I have the rear brakes apart I'll measure them.
In your case, if the rear is getting squirrely due to the brakes, wouldn't the ABS be intervening? Just curious about that.
#12
1) New rotor set (rotor ring plus hat) from Stasis (~$$900)
2) New Alcon rotor to replace what is in that pic there ($$$, I think a little over $1,000).
3) I have a set of rotor hats for the B-type you can take off my hands and order 2 rotor rings from coleman (~$300 depending if you choose slotted)
#13
I don't always succeed, but I try to stay out of ABS on track. I doubt that our ABS systems are designed to handle 40-50 activations in each 30 min track session, and I definitely don't want to be buying a new $$$ ABS pump.
With threshold braking and overcooked rear tires, I can definitely feel the rear end wiggling around a bit, but it's normally not severe enough to activate ABS. The few times that ABS has intervened has probably been when the wiggling became excessive. Anyway, that's my guess as to what's happening.
#14
with them...I have have had almost zero fade and very consistant pedal feel with the pads. IMO they deserve to be higher on your list....but that is just me
#15
Scandinavian Brake Systems (<a href="http://www.sbs.dk/">SBS</a>) offers three different pad compounds, but my Pad Comparison shows only the Ceramic, a pure street pad they call "Pro Touring". You're the first I know of to use the Ceramic/Carbon, which SBS calls "Pro Track" and is probably a dual use pad. Their third compound is the "Dual Carbon Pro Race", clearly their full race pad.
If you write a paragraph about your experience with the Carbon/Ceramic, I'll add it to the <a href="https://forums.audiworld.com/a8/msgs/81590.phtml">Pad Comparison</a> :-)
#19
I have that setup on my B5A4 with Brembo racing rotors. I have a used pair of rotors/hats sitting at home and another set on my car (warped). Stasis won't sell me new rotors, stating that they've discontinued that product (had it for less than 2 years when this happened). New Alcon rotor rings won't fit because of different number of bolts used. I don't know if I want to pay $ for Colman stuff. I'm left with only one option - buy a different kit. The Alcon B-type setup was a fantastic setup while it lasted. It's been the most expensive disposible product I've ever purchased.
