Offset?
might be better in wheels/tires forum, but check the link for easy description
<ul><li><a href="http://www.audizine.com/forum/showthread.php?s=&threadid=93664&highlight =offset+picture">Click here</a></li></ul>
For a brake rotor hat,
Offset is the distance between the hat's hub mounting surface and the mounting surface for the rotor on the hat. In this Hoerr Racing order form for a <a href="http://www.hrpworld.com/client_images/ecommerce/client_39/products/pdf_1521_1.pdf">Custom Hat</a> (pdf), it's dimension "D".
I doubt, however, that this definition of offset applies to one-piece rotors. In this case, offset is <i>probably</i> the distance from the hat's hub mounting surface to the centerline of the rotor (add 1/2 of the rotor width to the above hat offset).
For a radial mount caliper, the similar dimension that counts is the distance from the centerline of the caliper's mounting bolts to the centerline of the rotor, 42 mm in this pdf of my <a href="http://www.hrpworld.com/client_images/ecommerce/client_39/products/pdf_1015_1.pdf">Alcon TA6</a>.
onewickeda6
Wheels & Tires Discussion
04-07-2008 08:59 AM
secreTTasianman
09-13-2005 12:44 PM
