Removal of the OEM seat and the installation of the Sparco race seat.
First step is to remove the trims around the base of the seat rails. In this picture we are facing the back side of the seat and will have to remove the two small screws, multi point(T-19)inside the trims (centre) and have to pull the plastic plugs, two of them, one on each side facing inwards at the top of the trim.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST1.jpg">
Close up showing the little screw and the plastic cap/plug. Also note the big 12 point bolt. There are four (4) of these to be removed (later). They hold the seat in place in the car and are bolted to the floor. You will need a 10mm Serrated Bit with 12 points.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST2.jpg">
Both rear trims removed with screws.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST3.jpg">
Shot of seat railing without the trim.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST4.jpg">
Side view of seat where safety belt is attached inside.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST5.jpg">
Removal of plastic trim/cap.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST6.jpg">
Plastic seat trim/cap.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST7.jpg">
Removal of seat belt from its attach point on the seat.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST10.jpg">
Removal of front rail trim.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST8.jpg">
Front outboard rail without trim.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST9.jpg">
Sorry the next picture is out of focus. Two of four bolts that hold the seat in place with the 10mm Serrated Bit.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST11.jpg">
After all the trims are removed, the seat belt disconnected and the four bolts removed, tilt the seat backwards SLOWLY to rest its headrest on the back seat. The reason is there is a wire harness attached to it and to the car's floor. In this picture a plastic cap that cover the wiring is already opened at 90 degrees. You can see four separate wires going into the floor. The yellow round plug is for the air bag.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST12.jpg">
Remove the plastic cap.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST15.jpg">
Unclip the main harness from its secure attach point.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST14.jpg">
Unclip the four separate wires from their female counterparts in the floor.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST16.jpg">
Now that it is safe to remove the seat, do so. Be careful it is heavy, maybe around 70 lbs depending on options.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST17.jpg">
Re-install plastic cap to protect the now disconnected floor plugs.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST18.jpg">
Now it is time to remove the seat belt from the inboard side of the seat. You will need to unscrew it from the seat, disconnect the harness and unclip it from the metal frame (shiny gold colored clip).
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST19.jpg">
Seat after the removal of the safety belt.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST20.jpg">
Sorry again another out of focus picture. Home made 90 degree brackets to secure the two safety belts to the car floor. They will be attached to the floor using the same 10mm bolts that held the OEM seat in place. The 10mm bolt will go through the brackets and through the aluminum base to secure the whole installation as in the original seat.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST21.jpg">
Finally you can see the Sparco seat installed in the car, at least the back side on it. Notice on the far right the 90 degree bracket secured to the aluminum base and car floor by the 10mm bolt. The seat belt harness is secured to the belt by a tyrap. On the left side you can actually see the safety belt secured by its original attachment to the 90 degree bracket. You can also see it going through the seat's side opening.
<img src="http://pictureposter.audiworld.com/46874/SPARCOINST22.jpg">
Tomorrow the TopSpin safety harnesses are going to be installed.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
