What's the consensus on break-in for a new clutch
Old 12-14-2006, 06:17 PM
  #21
Phoenix80's Avatar
Default The S4/RS4 clutch has a self adjusting clutch mechanisim...however, if it is not set properly
durring install it will lead to early clutch failure.
Old 12-15-2006, 03:08 AM
  #22
Member
Aman_UnatrlyAspiratd's Avatar
LOL, I had the same thoughts when i read your post.
Old 12-15-2006, 04:20 AM
  #23
Member
Visti's Avatar
Default So you'll pay for the replacement and labour? you that confident? ok
MORON
Old 12-15-2006, 06:38 AM
  #24
Turbonater's Avatar
Default You can spell AND understand my message, wunderbar
If you will guarantee that Jerry D will not abuse his clutch then I will gurantee that no repairs will be necessary due to following my advice. Now you will have to live in his car 24/7 to give me that guarantee but I assume you are dumb enough to agree to that.
Old 12-15-2006, 06:42 AM
  #25
Turbonater's Avatar
Default City km count? Why not use full throttle, especially in the lower gears
The clutch resists maximum torque only in the highest gear at peak torque. The gearbox multiplies the torque and that, as you will realize, is downstream from the clutch.
This is why worn clutch first shows itself in top gear while going up hills.
If a brand new clutch slips under full throttle in top gear it is quite simply defective. No special bedding in treatment is required.
Finally, it is advisable to slip a new clutch more than usual if you wish to speed up the process of making the clutch take up butter smooth. When you do this you should not slip the clutch excessively, but this is normal driving advice, not special treatment. If you choose not to do this then the clutch will take a little longer to feel completely normal, but not much longer.
Old 12-15-2006, 06:46 AM
  #26
Member
Visti's Avatar
Default ok
enough fun for me today.
Old 12-15-2006, 07:58 AM
  #27
Jerry D's Avatar
Default I took it to Independent, they agree with me, it doesn't feel normal..
So I took it back to my Dealer who did the install, they tried it, agreed that they CAN feel the shorter throw and stiff bottom end of the clutch and proceeded to give me a technical reason for what could be the cause.
At the end I was told to live with it.
Suffice it to say, I do not like how this clutch feels now. Not in the slightest.
Old 12-17-2006, 08:29 AM
  #28
Turbonater's Avatar
I liked this forum better when you didn't know when you were beat
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
Monsoonenough
10-03-2015 02:59 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-24-2015 12:06 PM
carlaudis4
Audi Original "S" Cars
09-24-2015 06:32 AM
Quick Reply: What's the consensus on break-in for a new clutch
