H2O/Methanol update
I knew someone else was thinking
about this application, thanks
Walter.<ul><li><a href="http://superchargedaudi.com/sc/index.php?showtopic=2740#">http://superchargedaudi.com/sc/index.php?showtopic=2740#</a</li></ul>
<center><img src="http://us1.webpublications.com.au/static/images//shop//hi/1003707473hi.jpg"></center><p>
web site. they have maf both boost injection control units on this site
http://snowperformance.net
the boost switch i was using died so its to upgrade and i might try something from the auto autospeed site. check out the the auto speed site, they have tons of info and several diffrent control unit that would work quite well.
Nitrous Fuel Mixture / Motor Speed Controller
Ref: High Performance Electronic Projects for Cars - Silicon Chip Publications.
Pulse a fuel injector in a nitrous system. When activated, it will fire the injector at a preset duty cycle, adding a fixed amount of nitrous fuel. This is a far cheaper alternative to a dedicated fuel solenoid and jets. It also makes a great motor controller, to control an electronic water pump, additional fuel pump, cooling fans and more. It is suitable for use with most fuel injectors, or pumps and motors up to 10 amps. Kit supplied with PCB and all electronic components.
whatever you do, dont spend 399 on that kit becuase at most its about 200 worth of parts.<ul><li><a href="http://www.autospeed.com/shop/category_579/browse.html">http://www.autospeed.com/shop/category_579/browse.html</a</li></ul>
x-ricer
08-13-2001 02:08 PM
QuattroRocket
11-15-2000 11:40 AM
