Russ - Take care of the TT on Tues/Wed.
Flatbedded the TT to you guys Mon. evening. Appears the clutch slave may have taken a dump. All of a sudden the clutch pedal had no pressure for the 1st half of travel and it was a little stiff changing gears and it would take putting the pedal completely to the floor to disengage the clutch, but finally the pedal just stayed on the floor and the clutch would not disengage. Just glad it was in 1st gear.
Also time for the 75k service. Dropping off Mobil 1 on Tues. morning.
Checkout the different rear end on the TT. It's not only Adam that has a pretty uneek TT around Chicago.
the clutch slave, what has to be removed to do the work?
Just wondering if clutch would need replacing.
