So I tried to replace the rotors and pads on the S4 yesterday...
The front pads were too easy.
The rears pads only a little struggle.
The rear rotors no problem.
BUT.....
Any suggestions on how to get the 21mm bolts off on the front.
I broke a couple tools trying to break 'em loose.
Once I figure this out, then the front rotors should be no problem.
Or am I missing a way to remove the front rotors easily.
TIA
BUT.....
TIA
The car had better be on jack stands.
Before I had air tools, I had the same issue. I put a breaker bar on the bolt and then positioned it so that I could fit a jack under the breaker bar. Then very carefully jack up the breaker bar. The jack adds a lot of "power" to the breaker bar.
MAKE SURE IT IS in the correct direction. If not, you will either break the head off the bolt, or you will round it badly.
OR.....
You can remove the pads from the caliper and try to snake out the rotor with the pads out and the caliper still on. It might work.
good luck
OR.....
good luck
Leverage can be a beautiful thing if you have the room to work.
If that doesn't work....
PB Blaster
Air tools
Swear a lot
Drink beer.
PB Blaster
Air tools
Swear a lot
Drink beer.
I did try a pipe on the breaker bar, and the cheap as breaker bar broke. So off to buy a new one to day.
I do wish I had a lift then I could try a REALLY long pipe. But hence I do not have that luxury.
clear access to the bolts? Then slip a jack handle or pipe over a breaker bar. you can get good leverage that way. Impact wrench helps too.
Where are you located? maybe I can help. DON'T BREAK ANYTHING!
d
d
