Events Discussion Discussion forum for Audi events, shows and happenings
2008 Audi A8L VCDS fault code 01275 (V71)
Old 07-23-2018, 04:09 PM
Jrathod's Avatar
Default 2008 Audi A8L VCDS fault code 01275 (V71)
VCDS gave me fault code 01275 (V71) air flow positioning motor 003- mechanical failure - intermittent. Will appreciate any guidance on fix and which one of the four motors in the HVAC system would it be. One of the two outside at the air intake or one of the two behind the glove compartment? Apparently there are are total of four motors from what I can tell. Also could the intermittent be because of setting or damaged motor? Any feedback will be greatly appreciated.
Old 07-24-2018, 11:52 AM
Vicl's Avatar
Interesting! I noticed the same error on my Audi A8 2007.
Planning to explore the Elsa how to re-calibrate it. Will let you know the steps and if it solved the issue.
Old 07-24-2018, 02:25 PM
Jrathod's Avatar
Thank you for your quick replay. Yes please do let me know if you get any information. The VCDS code I got is 01274 and not 01275 which I had labeled inadvertently in my original posting .
officer120
Q5/SQ5 MKI (8R) Discussion
10-07-2019 11:09 AM
joe9904
TDI Discussion
01-22-2018 02:47 PM
Samidkhan
S4 (B8 Platform) Discussion
03-12-2017 08:12 AM
Artauto
10-19-2014 08:56 AM
charlie croker
Audi 100 / A6 (C4 Platform)
02-08-2002 02:58 AM
Quick Reply: 2008 Audi A8L VCDS fault code 01275 (V71)
