AWE GT28R turbo on stock mani? Not a bad alternative to avoid BT headaches!
not too sure about using the stock manifold, but the cost isn't too bad and the power seems good for stock manifold, not sure what injectors<ul><li><a href="https://forums.audiworld.com/midatlantic/msgs/166058.phtml">https://forums.audiworld.com/midatlantic/msgs/166058.phtml</a></li></ul>
Didn't they do something similar for the transverse engines a while back?
I heard you moved. What gives?
Does Unitronic make anything for the Acura or is Hondata the only choice? Wanna become a Hondata dealer?
So if I get it, you gonna come help me tune it?
Supposedly you can get another 30hp out of a stock car with timing and cam timing adjustments. Scott's buddy is trapping 100mph with just intake/exhaust and Hondata.
Or if VAG had used Garret for the gas cars instead of the TDIs, then they would be plug and play
like ALL of the other factory turbo cars!!!!!
But in the home market, diesel is king so it makes since to give the antiquated KKK tech to the gas cars.
