Changing brake fluid with Motiv power bleeder.
Is it safe to remove brake fluid with a Motiv? Basically I would attach the Motiv to the reservoir with no fluid inside, pump it up to 20psi and then open the bleed screws until no more brake fluid comes out. When it's all done, attach the Motiv with brake fluid this time and bleed as normal. Some dude at the track told me to do this but I'm not sure it's the right way to do it. To this point, I've been removing as much as I can from the reservoir, then bleeding the brakes with new fluid.
There are directions on their website.<ul><li><a href="http://www.motiveproducts.com/10instruct.html">http://www.motiveproducts.com/10instruct.html</a</li></ul>
99A8Q
03-31-2005 12:32 PM
S4inSoFla
12-26-2002 05:28 AM
hellboy
06-19-2001 01:21 PM
