CRAP! Small oil leak found
Last week while working under my car I found oil on the side of the pan near the drain plug (passanger side). I thought it was residue from my oil change 1000 miles prior so I cleaned the area really well and put the car back together - BPV shim
. So yesterday I decide to check to make sure everything is cool and I find another drop. It looks like it is coming from the front passenger side corner of the pan where it bolts to the block and some other piece of aluminum that's also bolted to the block. So, what is involved in removing the pan to replace the gasket? If it's only leaking MAYBE a teaspoon every couple weeks (have yet to find oil on the under tray) is it safe to leave it until my next oil change?
I also checked my timing belt for signs of oil (cousin had a front main seal go bad on his old 626 and the timing belt had oil all over it). No oil was seen on the belt.
Car also runs fine, and pulls as hard as it ever has
You might have a loose oil pan bolt. Don't try to tighten it youself. They're really brittle. Just have Jorge or Mike look at it during your next service. I'd keep and eye on it until then...
btw...How did the shim in the valve work out?
Good. The aluminum ring is 3.5mm. Response is better between shifts so I'd say it's doing what we thought. That's really the only difference I notice.
The oil leak kinda sucks, oh well, I'm sure Mike or Jorge can fix it.
Jorge fixed it on my wife's car not too long ago. Oh, but wait...you are modified....
"All you warranty are belong to us"
Yeah, my 1 bar MTM chip caused my oil pan to leak
I personally think having a motor mount ON THE OIL PAN is a bad idea. I can't imagine the stress put on the pan with the APR Snub mount.
Crankcase pressure is directly related to the amount of oil in the engine, IE low oil level, decreased oil pressure - right Green!
I could be wrong, it happens from time to time
to the crankcase. Under boost, the valve closes. Unfortunately this valve was never designed for 16psi so some boost is vented into the crankcase. Take one of your pre intercooler pipes off and you will probably find a light coat of oil. This is caused by some of that boost also blowing into the little catch can device on the intake track between the MAF and the turbo inlet.
