forge diverter valve
i just recently bought a forge 007 diverter valve...i had racing zone put it in..its sounds just like my stock...is there a way to adjust it or open it up to make the sound louder?
You can reverse it for a little chirping noise, but you will probably need to install a stiffer
spring. I tried different spring/shim combinations until I found one that opened at the same vacuum as the OEM valve. For reversed installation, you will probably want its just a tad stiffer than stock. You will need a vacuum gun to figure all this out.
pat33
09-16-2003 01:23 PM
govugo
12
07-30-2001 04:00 PM
