Freaking Jiffy Lube!!!!
Old 12-28-2005, 11:55 AM
Mr. Head's Avatar
Default Freaking Jiffy Lube!!!!
Apparently that is who dis jessica's car's last oil change. Turns out that the moron that did it, crossthreaded the drainplug into the Oil pan and completely stripped the oil pan...
more to come...
Old 12-28-2005, 12:02 PM
Mr. Head's Avatar
Dave, can you give me a call for a quote on an oil pan for an 01 jetta 1.8t?
Old 12-28-2005, 12:34 PM
mike*green's Avatar
Crossthread's better than a lock nut.
Old 12-28-2005, 01:01 PM
Longwolf (Christian)'s Avatar
Default This is another example why I want to slap people silly for going to Jiffy Lube.
So many horror stories, why do people do it?
Good luck on getting Jiffy Lube to admit liability and to cover the cost of a new pan.
Old 12-28-2005, 01:52 PM
Jon-1.8t's Avatar
Default Is the oil pan cross threaded or nut? I would try and re-thread it.
Harbor frieght sells a die set. Oil pan is not gonna be cheap.
Old 12-28-2005, 02:13 PM
Rice Etr's Avatar
Helicoil
Old 12-28-2005, 02:14 PM
Rice Etr's Avatar
Most likely its the pan. Aluminum pan, steel plug.
Old 12-28-2005, 04:40 PM
A4_Mation (Dave@ETA)'s Avatar
Default Meyle $89 w/ provision for oil level sender w/o its $87
OEM oil pan w/ provision with oil level sender $175, easy choice
Old 12-28-2005, 05:03 PM
Mr. Head's Avatar
Default Here is the story...
The steel plug stripped the threads the entire way through the Oil Pan.
<img src="http://pictureposter.audiworld.com/45027/oil_pan.jpg">
<img src="http://pictureposter.audiworld.com/45027/threads.jpg">
There is not enough metal left in the Drain pan to rethread the hole for the same size bolt. I could retap the hole for a larger Metric bolt, however, I don't feel comfortable doing that with the pan on the car. The metal shavings due to tapping the hole will not be attracted by the magnet in the pan due to the fact that Aluminum is not Magnetic.
So that is going to leave the only hope of capturing the threads and shavings up to the Oil filter. Depending on where the oil goes first, it may not catch it...
Cant do a helicoil due to the fact that you can see in the "threads.jpg" that the treads are no longer there.
Only options are a new oil pan or a removal/reatapping.
Old 12-28-2005, 05:43 PM
well, only $89 from Dave, easy choice. Get the new pan.
Quick Reply: Freaking Jiffy Lube!!!!
