horse power/boost question
What is the approximate horse power difference if someone is running 25 pounds of boost vs like 20. I have been running 25 for 8 months but my turbo died and plan on backin it off but I am still curious how much of a difference there will be. I probably couldn't tell by driving on the 2 different boost settings. right?
thanks.
thanks.
or if you have a really efficient turbo that flows a lot more air, like the garretts, at 10psi my 28rs makes more power then a K03/K04 @ 15-18psi
the fuel properly (running lean/rich, too little timing, too much timing) you will not make power efficiently. there are a lot of factors involved with running at peak performance.
I also have the sps3 and want to put race gas in it. is it silly to put 109 in it increase the timing but leave the boost at 22ish?
now you're prolly running a diff turbo if you said you were running north of 20. A decently sized turbo like a GT28RS will see good power differences due to the volume of air that it puts out
