Need a good hack. Changed network ID from domain to workgroup. Now I'm locked out.
Was trying to add the comp to my home network. Obviously I didn't know what I was doing. The PW that IT gave me doesn't work so they're not sure what was used now. I found a hack to use but it looks fairly complicated and I don't want to make things worse. Any suggestions?
However, the instructions appear farily complicated and are very unclear. They seem to assume that the user has some familiarity with the "innerworkings" of windows for which I have NONE. I'm affraid I'll make matters worse if I try to use it and screw something up.
Only problem with that is, I need to get my computer running. If I need to change the auger on a combine from a rotating to reciprocating type I'd be all set. You're only a phone call away though! If you can help me out, I'll make sure Christian and Breeze find a great sushi place when they're up here this weekend...;-)
BlackS4CH
Rocky Mountain Discussion
09-11-2005 08:07 AM
BeaverTTon Guy
11
08-19-2002 12:56 PM
