So I Just found Out I need a new motor for the B6? What should I do
Audi called today and said that the B6 has a bent Rod in the second cyclinder...SO the motor needs a complete overhaul or a swap
What should i do?
Is there a crate built motor solution or do i have my guys in Maryland (induktion motorsports) build it bullet proof.
I would like to keep this under 5 grand but, that is probably a pipe dream
What should i do?
If you go with a used motor watch out for sludge, but probably not a bad option. Under 5 grand? Get a used motor, have the oil pan & valve cover removed, check the cam bearings for wear, check/change the oil pickup tube, do the usual TB stuff. This is a 1.8t, correct? That should keep it around 5k.
or just try the ebay thing, but be careful. I have seen a few motors in on car-parts.com that can be found local.
this time, keep the motor stock
or try different software
p3u
10-21-2008 06:59 PM
Rub-ISH (Brandon)
1.8T Discussion
9
08-18-2006 08:20 AM
MR711
03-11-2005 07:56 PM
Leafhound
10-22-2004 04:33 PM
