Where in Orlando can I pick up a pallet of St. Augustine Grass?
Make sure you get one of those big aluminum landscaping rakes from Lowes or HD. They make ground prep a LOT easier.
Dont forget to spread a good coat of Lime before laying the sod. Rake up the dirt->smooth it out->Spread lime->lay sod->roll sod to get air out-> water, water, and water.
There are 2 other places as well and I can give you a name/number once I get home.
A pallet covers 400sq ft and will cost you abuyt 80 plus a pallet deposit (usually $5). Delivery for a single pallet will be $20'ish unless you get it yourself.
On another note, I got a name of a guy who does st. augustine installed for .36 or .38/sq ft(forgot which). That's 50/50 even split for the sod and the labor, if you don't feel like doing it yourself. He actually gets the sod cheaper then you can.
Then it won't really matter what kind of St. Augustine you get, but it's best to match what you have. Cut out a small section and bring it in, they can give you a matching kind, or a near equivalent for what they happen to have.
